RCU Forums - View Single Post - Hangar 9 Twist 3D
Old 05-24-2006 | 05:40 PM
  #3945
PropHanging
Default RE: Hangar 9 Twist 3D
ORIGINAL: Jack211
Here's what to do (if I can do this without graphics): take a 15 inch piece of very tough thread (fishermen use common sewing thread, but you can get thicker stuff, but common thread WILL work). With your left thumb, press one end of the line on the rod, starting where you want the coil and leaving about three inches of line under your left palm. Make a 2 inch loop running along the rod. holding the "top" ends of the loop under your thumb. Squeeze the bottom of the loop so it is very narrow, making two parallel lines. Then you have a thin loop running along the rod with a three inch tail under your left palm and the other, long tail, hanging down from the thumb. With your right hand, starting at your left thumb, wind the LONG tail tightly over the loop and rod time and again, going from left to right. It will look like a spring wound around the rod. Keep the coils reasonably tight so they secure the loop and don't go over one another. When you get about 1/4 inch of coiling along the rod, you'll still have a loop to the right. Take what's left of the long tail and thread it THROUGH the remainder of the loop.
Jack (believe me, I'll hear you cursing me as you try that coil the first couple of times :-) )
Jack,
The instructions you gave me were great. I understood everything up to "take a 15 inch piece of thread. I did print the instructions and will give them to a friend who may be able to translate, as he was in the navy. I will get if figured out. Thanks for the help. I think you'll like the Extreme 330. Built one for a friend and have flown it several times. It handles really well. You may need to do some trimming to get the 50 in there. We did on his model.
I still have about 3 feet of carbon fiber tubing left so I'll probably just replace it, wrap it, and CA it (thanks Down) for now and see how it holds up to that.
