RCU Forums - View Single Post - Excelleron 90 problem
Old 05-24-2006 | 10:37 PM
412t1
My Feedback: (7)
Default RE: Excelleron 90 problem
Ernie,
It actually was pretty easy. I peeled back the gold trim on the bottom and the orange and yellow trim at the top to make my horizontal cuts so I could hide those cuts under the trim colors. I then peeled back the white covering. When I opened up the side, the pull-pull cable tube wasn't really supported by formers so all I had to do was cut a new hole in the fuse side piece where I wanted the cable to exit and gooped the tube in place. Once that dries, I'll ca the balsa back down in place, blend the seam and fill the old hole so no one will ever know I cut it open and reapply the covering I peeled back. Hopefully the vertical cut in the white won't be too noticeable.
Shawn
