RE: ???'s about upgraded alum. shock assembly
ita takes a bit of force. I used some regular pliars and squeezed onto the shock shaft as hard as possible so that it couldn't spin. Vice grips would be even better. Then to spin the eyelet, just put a screwdriver throuch the hold and use it for leverage. Once you have it threaded the first time they will go on and off a lot easier.
