RCU Forums - View Single Post - Kangroo control surface throws
Old 05-25-2006 | 04:01 PM
Hobby Inn
Default RE: Kangroo control surface throws
The manual calls for 25 mm for elevator and aileron functions. You need it on the elevator, but I recommend you double or triple rate the aileron for your first flights until you find out what is comfortable. I found 15 mm on the aileron was about right.
You will also need about 1/8 inch reflex on the elevons (up).
Have fun....great jet.
