Revo Diff in T-Maxx Diff Case
Can anyone help me figure out how to run Revo diff (internals) in T-Maxx diff cases. I have done some research and the only info that I still need to figure out is bearing widths for the output shafts. Other than that it seems like it would work fine! I know that I need a 10x15mm bearing on one output shaft and an 8x15 on the other side. The problem is I don't know if the standard width 10x15mm bearing used in the T-Maxx will work and I don't know how wide the 8x15 bearing needs to be on the other side. Obviously, if the bearing widths are wrong then the ring and pinion clearance could be wrong and the diff may not fit properly in the case.
I currently run Revo diffs in my T-maxx for the T-Maxx only racing class that we have at my local track. Last year I modified my T-Maxx bulkheads to run the entire Revo diff. Since modifying the bulkheads is a pain in the ***** I want to find a way to run the Revo diffs(internals only) inside stock T-Maxx 3.3 case. This would allow me to have sealed diffs without butchering my new bulkheads. Also, I know that T-Maxx 2.5 and 3.3 diff housings are the same except for 2 extra screws so my question applies to any T-Maxx diff case.
If you have any info on this your help would be appreciated!
