RCU Forums - View Single Post - CMPro Lancair
Old 05-26-2006 | 07:28 AM
  #68
Hot Rod Todd's Avatar
Hot Rod Todd
Default RE: CMPro Lancair
I think I know where your coming from. It was a bit painfull shelling out the money to get an AstroFlight charger that could handle the high current 4S and 5S cells.
Don Glider Guy: I have no problem rotating on take off. Of course the power set up I have has outstanding excelleration. In any case, this is not a plane you want to jump into the air, give it plenty of speed prior to pulling up. You might want to have a bit of down elevator trimmed in from the start, if it's like mine it will want to climb. Good luck with your maiden flight.
