maingear problem
now i got the motor to run, by buying a new esc.. i also changed the main gear because there was a couple teeth missing...
now i went to get some flight time and now for some reason the motor is now spinng the main gear the wrong way... its spinnging the main gear but the blades arent getting any power...
looking from the top of the heli, the blades are suppose to move clockwise, same with the gears?? when i throttle up, the motor is spinning the gear counterclockwise from top view...
