RC Helicopter Beginners Forum If you are a beginner or "newbie" to RC heli's feel free to post your questions right here in the rc heli beginner forum.
maingear problem
Old 05-27-2006 | 09:09 PM
Default maingear problem
now i got the motor to run, by buying a new esc.. i also changed the main gear because there was a couple teeth missing...
now i went to get some flight time and now for some reason the motor is now spinng the main gear the wrong way... its spinnging the main gear but the blades arent getting any power...
looking from the top of the heli, the blades are suppose to move clockwise, same with the gears?? when i throttle up, the motor is spinning the gear counterclockwise from top view...
Old 05-27-2006 | 09:18 PM
Default RE: maingear problem
can you switch any two of the motor wires, understanding there are three??
Old 05-27-2006 | 09:22 PM
yes there are three.. from the motor, its red, blue, black
from the pheonix esc, red, white black
i just matched the red and black together and than the white to the blue
which one should i switch?
Old 05-27-2006 | 09:25 PM
ORIGINAL: shift_350zz
The polarity on the motor is reversed.
If it's a brushless motor (3 wires), swapping two of the three wires going to the ESC may reverse the direction. Try different combinations of swaps. Doesn't matter which two you swap ... a brushless motor is essentially a 3 phase motor. Swapping one pair of phases (two wires) will change the direction of operation.
If it's a brushed motor (2 wires), reverse the wires going to the ESC. If the wires from the motor has a non-polarized connector (can be connected in two ways), just unplug the connector, flip it, and plug it back in. If the connector is polarized (can be plugged in only one way) then you may have to unsolder the wires from the motor, flip the wires, and resolder.
Good Luck,
d.tipton
Old 05-27-2006 | 10:07 PM
thank you very much, i switched two of the wires and the motor is now revving the right way...
