RE: CT5 steering problem
I'll have to take pictures tomorrow (camera's down right now) look at the outter steering ball joint connected to the hub you'll notice you can see the phillips head. Follow that to the linkage in the center and you'll notice the other ball joint snaps on the ball. Replace the out style with the inner style and you should be good to go, if it's still binding just pop it off and on acouple of times and you should be set.
Todd
