RCU Forums - View Single Post - Question about using micro servos on a propjet
Old 05-28-2006 | 04:48 AM
propjets4me's Avatar
propjets4me
Default RE: Question about using micro servos on a propjet
the torque value sounds fine , and as most have noted it's speed would be around the 100mph mark..so even if used at the high speed level they should do fine...usually I think the micros etc fail due to vibration issues when you use them on a throttle, I can't see that being the case here, and even if you do have a failure I dont think it would be critical in bring the plane in ,
