Ideas? Well I think a lot has to do with this quote....
....then made a huge right hand turn sight (as in "straight"?-bcm) in to the ground....
How much time did this turn take and what were you doing on the controls when it happened? If it took more than a second and nothing you did seemed to help then I'd suspect radio problems too.
DR, what sort of rough life has this set had in the past?
