Originally posted by Mendes
I like to use 4-40 bolts and T-nuts, all you need is a plywood plate inside your wheel pant for the T-nuts to sit in and your bolts go through the landing gear and into the T-nuts. It's really a strong setup, just make sure that your bolts aren't so long that they will touch the wheel when installed.
Mendes,
Do you have any pictures of the setup? Also, what exactly is a "T-Nut"?
thanks
