RCU Forums - View Single Post - Hobbico Avistar ARF
Old 05-30-2006 | 11:55 AM
Scar's Avatar
Scar
Default RE: Hobbico Avistar ARF
ORIGINAL: bmannrcflyer
Hello. I have bought two of these planes, and the first one we crashed of what we thought was piliot error but as we built the second one we found that the engine had trouble getting fuel to the carburetor. We believe that the fuel tank is to low and that the carb is too high. This could or couldnt be the problem but this is an ARF and we have built the same plane twice with the same outcome...
What do you suggest I do to fix it? Thanks
Got a picture? Show us how you've mounted the engine.
It would be possible to mount the engine higher than the tank. If the appropriate clearances are cut into the cheeks, the spinner should be at the point of the cheeks and your carburetor will be aligned with the tank.
Best wishes,
Dave Olson
