RE: Hobbico Avistar ARF
Do you have foam around your tank? If not, put some extra under it to raise the throat of the tank to be square in the hole. It sounds like either its just too lean, or your fuel is just foaming. I forgot to ask, do you have a spare engine you can drop in it. To test if its the tank or the engine.
