RCU Forums - View Single Post - Control Throws for World Models Intruder 90
Old 05-31-2006 | 12:45 AM
NM2K
My Feedback: (14)
Default RE: Control Throws for World Models Intruder 90
ORIGINAL: rdrude
I purchased this plane used at our club's annual auction . It appears that this model has been discontinued. I have been unable to find an instruction manual on the net to get the control throw settings. I also emailed Airborne-Models to get the info from them. They did not reply. Do any of you have the throw info for this plane? Any help you can provide would be appreciated!
Thanks in advance...
Rob
Set up the controls to have as much throw as possible without making the servos buzz when the sticks are pushed to their corners.
Now, after that is done, set up your low rates (dual rate radio) to have about 50 to 60% as much throw. Take off with the dual rate switch in high rate. Only switch to low rate if you absolutely need to do so.
Make sure the balance point of the model is at the 1/3rd point (high point) of the airfoil and balance the model from side to side. You can do the latter by holding it upside down.
This model is not a trainer. If you can't handle this model on high rates, you have no business trying to fly it alone at a busy flying field. Get some help and good luck to you. That is a very popular model.
