RCU Forums - View Single Post - .46 Cen engine one way bearing issue
Old 05-31-2006 | 10:02 AM
merchjo
Default .46 Cen engine one way bearing issue
Guys
Have you seen issues with the one way on the .46 Cen engine? Mine only seem to last 2-3 tanks before they start slipping. I have the roto-start installed but I had the same issue with the pull start, the only dif is the pull start ones would last 3 times as long. I have also replaced the shaft the bearing connects too with no luck as well. This is starting to get expensive.
