RE: .46 Cen engine one way bearing issue
michelob78 - thank you for your help. I have used Odonnels but my most use is bashing and using Odonnels caused my engine to run around 300 so I stopped using it. As for cleaning the bearing I would soak it in motor spray, should something else be used? I will try the other suggestions.
