ORIGINAL: Jascat100
The other cure is, use the Inwood models electronic retract valve. When you switch off, the air pressure is left on the retract down position.
The valve is also much cheaper.
Regards
Thanks Jim.................I'll check them out. Have you had an issues with reliability with the inwoods unit ??
