RCU Forums - View Single Post - Jet-Tronic valve problem ??
Old 06-01-2006 | 05:24 AM
Jim Cattanach's Avatar
Jim Cattanach
Default RE: Jet-Tronic valve problem ??
Hi Demon,
I have used the inwood retract & brake valve units for around 2 years with no issues. They are not so good looking, but they do not need any setting up.
Just make sure you connect the up & down pipes correctly or, the retracts go up when you switch off. Not a good idea.
I have had problems with Jetronic valves.
Regards
