RCU Forums - View Single Post - Mini Bladerunner question
Old 06-01-2006 | 10:06 AM
toader32's Avatar
toader32
Default RE: Mini Bladerunner question
If the pinion gear is slipping and moving out of position, just slide the pinion gear down a bit and apply a small dab of glue on the motor shaft....then push the pinion gear back up into position. I had to do this with my Mini Dragonfly King. Works good now. Make sure you don't get any glue near the motor output bearing.
