RCU Forums - View Single Post - Hobbico Avistar ARF
Old 06-01-2006 | 10:27 AM
donhef
Default RE: Hobbico Avistar ARF
My Avistar runs great with the tank in the stock position also. The only problem I had was the original tank sprung a leak at the seam around the stopper. Once I replaced it with a Sullivan seamless tank, I've had no problems at all. I'm running an OS 46FX in the stock mount with no other modifications. You might want to check the forward seam for leaks. Good Luck!
Don
