RE: How do I install a .28 engine in my Nemesis?
We are currently working on an engine mount for the .28 conversion. Until then you will have to make some engine mounts if you wish to go to the .28.
Also we are finding through testing the .28's on our Nemesis that it is also nesseary to go to the Genesis pinion gear setup of 17, 21 over the stock Nemesis gearing of 21, 25. What this does is allows the .28 to help pull a little harder out of the turns.
The .28 engine mount should be avalible by the end of the summer.
