How do I install a .28 engine in my Nemesis?
WA
Hey guys,
I want to put a .28 engine in my Nemesis. How do I install a .28 engine in my Nemesis, do I need a new motor mount, and clutch set up, or can I just drop it in? I am trying to make it as light as possible so that I can make it race read. If anyone who actually has done this modification and can post a walk through I would be eternally greatful, thank you for your time gentlemen, good day.
Regards,
Haldir
Regards,
Haldir
My Feedback: (7)
KY
As far as I know you can use the same clutch bell but the motor mount requires redrilling mounting holes and tapping them out. The stock motor mount holes would place it too far back and I don't think there is an optional mount available for .28 engines.
Cen has a .28 motor mount in the works you can mod it your self but its a lot of work i my self run a .28 on my nemesis make shore you have a good dremel set
WA
ORIGINAL: blackrain
CA
We are currently working on an engine mount for the .28 conversion. Until then you will have to make some engine mounts if you wish to go to the .28.
Also we are finding through testing the .28's on our Nemesis that it is also nesseary to go to the Genesis pinion gear setup of 17, 21 over the stock Nemesis gearing of 21, 25. What this does is allows the .28 to help pull a little harder out of the turns.
The .28 engine mount should be avalible by the end of the summer.
WA
That is awesome, I was thiniking of selling my Nemesis but not anymore, as long as there is practical aftermarket support from Cen.
