RCU Forums - View Single Post - Need help on Engine ID
Old 01-07-2003 | 03:00 PM
Antique's Avatar
Antique
Default Need help on Engine ID
Plug the battery and sensor into the circuit..Lay the spark plug against the cylinder and turn the engine past Top dead center..the plug should spark..
Specs...Bore 1.73, stroke 1.34..Made from a Sachs model 111 or 115 chainsaw with a machined case by A&M...Look at the con rod..If it's copper color it's a Sachs, if it's not it was made by A&M...
Mix the oil at whatever the oil manufacturer says, usually 32 or 50-1 ....
