RE: COVERING A DIAMOND DUST
You could probably do the same thing with 3/4" wide strapping tape. CA glue one end of it down, then pull it tightly across the span and then glue the other end down. I think this span wise "trick" could cause the covering to cup in a unaerodynamically way at speed.
