I'd just like to say a few things here to anyone else who might be having a problem.
Try knife edge flight, and mix in appropriate elevator to track in knife edge good. This will help in torque rolls when you input rudder.
Practice
As mentioned, if you are looking at 3D (including torque rolling) you must have an aft CG, it will make things a LOT easier.
Practice
3W props are Mejzlik props that 3W has bought and applied their own decals to (as is my understanding). But prop choice is a matter of personal preference.
Practice
One quick hint, if you notice you start to fall out of a torque roll, you may have blanked out the tail. How many times have you started to fall out of a T.R. with full elevator and little rudder authority? Airflow coming off the elevators at their extreme deflection makes the rudder useless. Perhaps try easing up on the elevator just a bit at the onset of a fall out. Easier said than done though when you're contesting P.I.O.
