RCU Forums - View Single Post - Hinge Points in non-Pro Kits
Old 06-03-2006 | 03:38 PM
GPS
Default Hinge Points in non-Pro Kits
I have a Raven kit - got it quite a while back, only got around to building it last week. I was thinking of using mini hinge points as per instruction's suggestion. As there are no slots, etc. in the wing/ailerons/rudder/elevator (as in the Pro kits), what is the best way to install the hinges? Cut slots? Drill holes? If holes, how do you get them straight? Also, what is the best glue to use - foam safe CA, epoxy, polyurethane?
Are there other/better/easier alternatives for hinges for this kit?
