Hi Their
I have an Lt-40 which came out too heavy because I layed balsa sheeting on it . So I decided to rebuild the tail surfaces to original
spec s . I am going to cover it with Koveral and Dope . I have purchased the nitrate and butyrate dope , along with stix-it This is my problem .
If I apply the Koveral with the nitrate do I do the edges first , or do I overlap the edges with the Koveral . And if I use the stix-it , do I use a heat iron to apply the Koveral than apply the butyrate and when do I use the heat iron on the Koveral . As you con see I m missing the proper procedure . If anyone knows of a site that has this info , it would be a great help . I have already E-mailed Sig to try and get this info and am waiting for an answer . The cans do have some info , but not all the info that I need . I don t even know what sand paper to use . This is my first kit that I am building and it was purchased for the reason , to learn how to build .
Any help on this subject would be appreciated
Take care and support the troops .
Mike
