Yes, hard chroming will work fine.
But it may only need a little 400 wet or dry sand paper scuffing or a brake cylinder hone run through it.
Most worn model engines I've been around would have no wear ridge at the top of the sleeve. Worst case was usually a deep scratch somewhere on the sleeve.
I'm assuming it is a ringed engine. You can get a new ring from Frank Bowman. You can send the whole engine to him and he can do it all if you want.
Frank Bowman
1211 N. Allen
Farmington, NM. 87401
505-327-0696 (6 pm to 9pm MST weekdays)
Email:
[email protected]
