RE: Need help with motor problems
At times I will get the same problem as you are describing and have ck'd and replaced the plug and ck'd all the other components.I find that when this happens,it is usually in the receiver start mode.I have found when I recharge the receiver and ECU battery to full charge,the engine restarts as before.The GSU does not show low voltage.Also if you are using on board propane bottle,purge it and refill.
