Your problem sounds just like the one I had when I first got my Blade CP. Did you check the spindle? It's the connecting part between the blade grips that helorookie referred to. If you can't get this part out, it means it's bent. That would most likely explain the wobble you still have left. Go to [link=http://www.bladecprepair.com/]http://www.bladecprepair.com/[/link] to learn more.
