RCU Forums - View Single Post - Mixing help
Thread: Mixing help
Old 06-07-2006 | 06:03 AM
tippy
Default RE: Mixing help
roverks:: ... i am very sorry i rechecked things and its the pitch servo that does not move when i move the throtal stick, is this someting to to with the mixing.
Now that's something entirely different ...
What heli?
Typically, one would would expect the servo plugged into the pitch channel to move regardless of flight mode or swash config when the throttle stick is moved fore/aft.
The only time I saw this happen is when the TX was set up for ACRO instead of HELI. In ACRO, it's obvious that channel 6 will not move with the throttle stick unless you've programmed a mix to do it. The TX needs to be set to a HELI type model.
Look in the manual (PG 32) to get to the PARAmeter menu ... and see which type you have ... options are ACRO, the glider modes, and the heli swash modes. Make sure this NOT Acro or glider. It should be set to the SWASH config of your heli.
Good Luck,
d.tipton
