RE: Goldberg Extra....again
Well,this one is going nowhere fast.These newer kits suck.Started off missing a couple of ply doublers,no biggie,cut some out of scrap.Then the rudder bottom that is a die cut piece is way smaller than the plans show,managed to fix that.Now,starting on the wing and some of the ribs are sticking out of the trailing edge about 3/32" then the notches on the trailing edge are way off from the plans.If i align the outboard rib notch with the plan,the others are off progressing to the inner-most notch being an 1/8 or more off.Im calling Goldberg tomorrow and see if they have an old version they will trade for.I havent seen any improvements with the laser cut version.If they dont have a solution maybe tower will take it back.
