Originally posted by coony2787
if i move the clevis out i will lose alot of throw, doesnt 3d well with less throw. however this may solve the problem. i really want to keep all the throw i have now because i was actually looking for some more!!!!
thanks
Chad
I understand your problem. The only other option I can give you is to replace the plastic servo arms (looks like dubro h.d. arms) and get some aluminum ones and use ball links. I wouldn't use ball links on the control surface due possibility of control arm flexing under heavy 3D loads.
Try it, it might work.
Andy
