RCU Forums - View Single Post - Which Class are You competing in?
Old 12-25-2002 | 04:03 PM
Geistware
My Feedback: (16)
Default Re: Snaps
While I know this is cheating, I will probably use my trainer switch. I noticed that with the 9C you can program 4 different snaps. I will probably practice until I get the snap so that it is right and then just practice on timing. Releasing the switch will be my skill measurement of this maneuver.
Originally posted by EXCAP232
Over (or under) rotate and 1 point off per 10% so if you miss it by 90% then there is a 9 point deduction for that problem alone. If you don't "bury" the snap then it becomes easier to control. Easing off the ailerons and elevator will help.
