RE: building first kit
exacto knife
razor saw
T-pins
4" x 12" sanding block -- cut it out of 3/4" pressed countertop particle board
thin CA
thick CA
30 min. epoxy
covering iron
heat gun
building board
workbench -- LEVEL and SQUARE!! Not some warped POS coffe table you dug out of grandmas basement
incidence meter (?)
allen wrenches
12" level
screwdrivers
corless drill
LIGHTS!!! -- working in the dark sucks
straight edge ruler
metal square
hinge slotter
wax paper
loctite
dremel tool and attachments
CG machine (?) -- I just use my fingertips on a trainer
velcro strips for battery and RX
latex foam for padding the RX
3/8" paint brushes for spreading epoxy
That should get you started. [sm=thumbup.gif]
