Sup,
I fixed my plane (evn though its a little crooked, it flys well)
I had to use my standard Rx before and it had dul rates (low, high..)
Now I'm using my micro Rx and I saved a lot of weight. But I have a problem (and a question
). On my transmitter I have dual rates, but they won't work with my small micro Rx. Will the rate thing depend also on the Rx? I've had several flights on my *high rate* plane now. It's wild, belive me.... I 'm not a bad pilot [&:] And it's hard to handle because the controls feel touchy. ROFL I can barely make a small correction, and the plane already twists and turns. Any suggestions?
Today I tryed rolling harrier and I didn't need ANY rudder inputs to stay on level! The roll's are so fast that I can barely see my plane.
Something is wrong with my control throws. If I push the elev/rudd/AIL stick completly down, it moves to veritcal position. I tryed a waterfall, and it made it in the size of its own!
Any suggestions? The controls just feel too touchy for me... either its my experiece problem or it is the control throws
Paul
