RE: Setting CG- hiding weights
Try using a larger airborne battery pack. You can get them with sub-C size cells, and move them to where you need the weight. Never ever use dead weight when you can use a weight that has value. You will get longer flights, and more flights between recharges. This applies whether you are balancing an ARF, or a scratch built model.
Bill, AMA 4720
