CAUTION: Removing the baffle in your muffle could and probably will result in more dead stick landings due to insufficient fuel pressure. I tried this on my first plane and I couldn't figure out why it kept dying!
The backpressure from the muffle keeps the fuel pressur up to an acceptable level. I would also recommend a one-way valve between the tank & carb to keep pressure up.
