RCU Forums - View Single Post - DA50r PROBLEMS<, thoughts needed!!!!!!!!!!!!!
Old 06-12-2006 | 09:00 AM
nonstoprc's Avatar
nonstoprc
My Feedback: (90)
Default RE: DA50r PROBLEMS<, thoughts needed!!!!!!!!!!!!!
Burbling in mid-range and quit after throttle back usually imply a rich low needle setting. try to lean it to 1.6 turns out.
Difficult to start after a few flights is an indicator that the ignition battery should be recharged/cycled. It happened to my 5-cell nicad ig. battery. Recycling solves the problem. Also make sure the ignition module's box is not completed wrapped in foam.
--qc
