RE: TS2 POST IT HERE...
Guys,
What type/sizes tank did you get with your TS2.
The one I got looks nothing like the one in the picture.
Mine is solid white plastic with 2 rounded sides and if I mount it with one of the flat sides down then the stopper that would normally be in the middle of the tank is off to one side or the other.
Also mine is new never used and it has a crack in the bottom.
It is where the top of the tunnel and the sponson meet.Not really sure how to describe where it is any better than that.
The crack is a not very deep and is around 3" long in one area and 4" long in another area
The crack is at a 90 degree area and would not be in the water once up on plane.
Any idea what i would use to repair the damage.
I was thinking lightly sand the area and run medium ca in there and place the boat on edge so the glue would harden it the corner
and over the damage??
Terry
