RCU Forums - View Single Post - TS2 POST IT HERE...
Old 06-12-2006 | 10:25 AM
Jerry Dunlap
Default RE: TS2 POST IT HERE...
1. The carb and vent outlets on the tank can be offset to either side. The important item is to be sure the carb pickup tube is close to the bottom of the tank.
2. Thin CA applied as you describe will help strengthen the crack. The cracks you've described are along seams and more than likely are surface paint cracks. The TS2 comes with a Warranty and you can have the hull replaced if you do not want to make the repair.
3. What color is your boat?
JD
AquaCraft Models
