RCU Forums - View Single Post - problem with 9C super glider programming
Old 06-12-2006 | 01:16 PM
Frode's Avatar
Frode
Default problem with 9C super glider programming
Hi,
I have a 9C super radio. I'm setting up a Opus V-ds glider with 4 wing servos/GLID2-flap configuration. I have set up all the mix'es so that I have butterfly/crow, full span aileron action and v-tail.
I have one problem when programing the butterfly function. When I activate the butterfly function by moving the throttle stick aft the ailerons goes up and the flaps down. When I now want to use the ailerons with max butterfly then the one aileron goes down and the other goes even further up beyond the limit I set for that aileron servo end point (EPA).
Is there some way I can program the 9C super so that the ailerons wount go beyond the programed end point limit in the up-direction when I also have the butterfly active?
Sincerely
Frode Lillebostad
