ORIGINAL: jongurley
NOGYRO, I appreciatte the response, I will tune the engine properly tonight, and will it hurt to do the carb plate brass tube mod anyway, and I take it I just take a brass piece of fuel line size tubing bend it to a 90 degree and solder it to the carb plate, and just run a piece of fuel line in a box in the fuse,, correct!!! ...
P.S> RCPILET, I am not a betting man, but if I had to put money on it, I bet you are Divorced,,
No, I'm happily married to a fine woman who is also happily married.
If my response sounds harsh--then good. It came out exactly as I wanted it too. Why anyone would be scared to adjust their engine is beyond me. You should have learned how to properly adjust a carb long before you got into gasoline engines. Gas engines aren't voodo. If you don't know how to adjust the carb, or you can't tell the difference between lean and rich--then get an electric plane.
Funny, I told you to adjust the engine, and you didn't like it. NoGyro told you to adjust the engine, and your following his advice.
