RCU Forums - View Single Post - DA50r PROBLEMS<, thoughts needed!!!!!!!!!!!!!
Old 06-12-2006 | 02:23 PM
Nogyro's Avatar
Nogyro
My Feedback: (10)
Default RE: DA50r PROBLEMS<, thoughts needed!!!!!!!!!!!!!
ORIGINAL: jongurley
NOGYRO, I appreciatte the response, I will tune the engine properly tonight, and will it hurt to do the carb plate brass tube mod anyway, and I take it I just take a brass piece of fuel line size tubing bend it to a 90 degree and solder it to the carb plate, and just run a piece of fuel line in a box in the fuse,, correct!
It won't hurt a thing to go ahead and do the carb plate mod. Just run the fuel line into the balsa box. The balsa box can be in the fuselage or in the engine box, doesn't matter.
I sent you pics of the carb plate mod to your email addy.
