RCU Forums - View Single Post - DA50r PROBLEMS<, thoughts needed!!!!!!!!!!!!!
Old 06-12-2006 | 08:15 PM
jongurley's Avatar
jongurley
My Feedback: (29)
Default RE: DA50r PROBLEMS<, thoughts needed!!!!!!!!!!!!!
Thanks for the suggestions DICKHANSON and nonstoprc,, O.K. since it is storming and raining like crazy here in North Carolina I took and did the carb mod just a minute ago, don't laugh at my mountain of solder I was by myself so I had to get buy, I soldered over the side hole in the cover and drilled out a middle hole in which you can make out(poor quality pics) the brass tube, then I built a small 1-1/2 ??? balsa box and mounted it in the fuse,,, I took and sealed the fuel hose into it,, anyway pic one is my mountain of solder and the brass tube, pic 2 is the box mounted in the fuse,, tell me if I did something right or wrong I think i is par everyone elses but I am not 100%..
ID:	476697   Click image for larger version
