RCU Forums - View Single Post - DA50r PROBLEMS<, thoughts needed!!!!!!!!!!!!!
Old 06-12-2006 | 09:01 PM
jongurley's Avatar
jongurley
My Feedback: (29)
Default RE: DA50r PROBLEMS<, thoughts needed!!!!!!!!!!!!!
Will do,, I took and put a small drop of ca to hold the brass onto the plate dead center,, I then got a drop of solder on it, and then I just went to town soldering I first of course roughed both the plate and the brass tube with a dremel I then soldered and let cool then I tried to pull out and it was dead solid,,, the I just built in about 2 minutes the balsa box and put the tubing into it and put RC56 canopy glue around it,,,,,,
