RE: Hangar 9 Twist 3D
Wow, Eric, you have some problems with that PNP. I have NO idea if it's a "PNP problem," but they say it's the same bird as the yellow, purple and pink item. At 4.5 CG you're in the middle of the range. None of it makes sense. I'm with Gary (Ghee-grose). I've never heard of these tip stall problems with a Twist.
What I want to ask is, is the motor running all this time? Did you forget to tighten the prop? Something's very, very weird.
Anyone with a Twist in your area to whom you can apply for another critical eye on that bird?
Keep feeding us more info. Maybe we can figure it out. Right now I want to fly that Twist. Sounds like a helluva challenge. LOL
J
P.S. Waldo, get some flight time, huh? You don't look so good.
