RE: Hangar 9 Twist 3D
My angle pro gives me the following...
Left aileron inside: -18
Left aileron outside: -19
Right aileron inside: -20.5
Right aileron outside: -18.2
Elevator Right: -15.8
Elevator Left: -16.1
Elevator Right-Left rotation: -9.7
Rudder right-left rotation: 81.5
I promise I tried to keep everything from moving as much as possible but it's kinda hard as the angle pro is kinda heavy and wants to twist the wood. It looks like my right aileron sucks a lot. and the left isn't very far off. My right/left halves of the elevator are pretty close and my vertical/horizontal tail planes are pretty much perpendicular. The stab looks almost perfectly parallel to the wing from looking at it. I would tell you if the wing is twisted but I have no way to measure it.
Hope this helps...
-Eric
I suppose I should add that the plane is around -16 degrees w ith the elevator. So my ailerons are actually pointed down a bit? I think that has something to do with the fact that the angle pro droops them a bit though.
