Sandor ...i left the pins exactly the same length as when you sent them ... very nice pins they are too...
... with flats on ..but i made a spacer to go over the pins the same dia as the top of the Oleo ... BUT the middle section of the spacer has 2mm clearence round the pin so the pin can bend.. the middle outer wall section of the spacer is quite thin..
Dave.
